  #53 (permalink)
Old 06-01-2009, 11:34 AM
elmariachi elmariachi is offline
Originally Posted by mr0077 View Post
El, David is right, the shroud you have is compounding your cooling problems, take it off. On timing, if you have the timing too retarded, it will overheat, particularly at idle. When the mech and vac advance come in at higher revs it will "solve" the problem a bit, but you would likely know something was wrong, 'cause the car would run like a dog if it was that far retarded. Still worth checking...
Okay guys, removing the shroud will back me up one notch to where I was last weekend. Car will run great and cool down the road, but will not cool well at slow speeds or idle. Can I safely advance the timing beyond 20*???
So....
Once I remove this shroud my car runs great at 180* down the road, no knocking/pinging/dieseling at shut-down. Car heats up to 110C if left sitting still long enough.
I am headed to do the coolant eval.
