Old 06-01-2009, 02:58 PM
olddog olddog is offline
Originally Posted by rbray View Post
These are all great points.
The clear fill hose is fuel rated. As far as grounding goes the cell is grounded to the frame. The fuel cap has a ground wire runs from the cap to the frame. Is this safe or do I need to ground the cap directly to the cell?
I would think that would be OK provided they are both good grounds. If both wires went to the same bolt on the frame, then in essance they will tied together. An ohm meter to the cap and the tank should tell the story. If you measure zero your good.
