Old 06-01-2009, 08:45 PM
elmariachi elmariachi is offline
Originally Posted by DAVID GAGNARD View Post
BTW: all my pulleys are single groove,old style V-belt.... David
So you mean your pulleys won't let me run A/C later?? Single groove is exactly what I need. Here's some good reference info on compatibility, the water pump pulleys are half way down the page: http://www.mustangtek.com/pulley/Pulley.html
Thanks!
Originally Posted by CHANMADD View Post
just a quick observation.... the holes that you have in the top plate for the hood hinges look like they will bleed quite a bit of air. I would find some way to make them smaller or fabricate a rubber seal.
john
Hi John,
The hinge slots would be a factor if it were overheating at speed, but they are not an issue at idle, as far as I can tell. I taped them up a week ago when I started trying to figure this out and it didn't matter.
