Originally Posted by razerwire
If you talk to fluidyne you could ask them what Finishline Motorsports Las Vegas used in the comp cars and what the specs are. I would call Finishline for you but they are closed. Then you could compare specs to your rad.
That's model FHP-30-SHELBY, same as discussed above. Its a 3-row versus the PRC 2-row. I am pretty sure I can make it work and use sheet aluminum to enclose the side up front in the nose. Its already setup for the correct driver-in, passenger-out ports and has the air bleed port from the expansion tank. The PRC Hurricane radiator requires a passenger side main hose exit on the expansion tank, reverse of the Fluidyne. This coming after I finally got my expansion tank to stop leaking.
So I got that going for me.
Restrictors and new IR gun arrive tomorrow, then we'll be doing more testing.
