  #21 (permalink)
Old 06-03-2009, 06:41 PM
tabey25's Avatar
tabey25 tabey25 is offline
Cobra Make, Engine: DRB SC540
Thumbs up
Originally Posted by WKB View Post
Paul,
I havn't heard when the glass will be ready. The window scraper for the inside will be the one from inside of the Falcon door with the clips removed and glued into place and glued in place on the top of the of the door. Along the top edge of the scraper you will notice a small flap. The top edge of the door trim will need to be peeled back and the fibreglass cut back a small amount and the trim re-glued. The edge of the door panel should then slip under the flap on the scraper. I don't know what the outside scrapers are yet.
Have you got the fibreglass adapter parts from DRB to fit onto the heater/air con unit?
If you havn't picked up the S2000 mirrors have a look at the late moodel MX5 mirrors. They look a bit easier to fit, available new, but no blinker units available for the covers.
Warren
Warren spoke a bloke in Shepparton over here about getting a noise test, he said need to hold the rpm up to 3,700 to 4,000 at a 45deg and about half a metre back but he said said if it pops when coming down it mite not pass and my does , need to do again when i get it back from paint the cost of doing it is $30.00
Michael
