Old 06-04-2009, 11:12 AM
FWB's Avatar
FWB FWB is offline
some additional info, the C-6 you currently have will rob you of 75 HP to the rear wheels. when the C-6 shifts from 1st to 2nd the drum must completely stop and change direction. the AODE will use far less HP to work. i have drag raced my 468 stroker with FB's trans and it is bullet proof. they will ask some pertinent info for your build and taylor a converter for you. they will even supply the correct speedo gear. the only drawback is the cost of the voodoo fluid they recommend. 112.00 gal. your trans mount will move to the rear about 1.5 inches. the driveshaft will also have to be shortened and balanced. both mods are easy to do. FB will tell you the exact dimensions of difference from your mount to theirs. GO FOR IT! you won't regret it
