  #21 (permalink)
Old 06-05-2009, 09:46 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
in the pic above the radiator is out of the gray car. both cars have the same radiator specs and are angled the same. be careful of the thickness on your fan, the black car has a shroud on the fan and has room to spare regarding the cross brace behind it. the gray car does not have a shroud and the fan is thicker and the cross piece had to be relieved and the radiator was spaced out from the frame 3 washers thickness. also be careful not to mount your radiator rigidly, i used rubber grommets with 3/8's id and 5/8 od with washer between the bolt head and grommet.
i don't know how you are going to mount it deeper because of the frame it attaches to. the top of the radiator is prob 3-4" to the inside of the opening.
