Old 06-05-2009, 10:48 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default Any appliance repair guys here? Bosch dishwasher problem..
Guys,
I have a Bosch SHU5302UC dishwasher. It has what should be a VERY easy problem to repair. The drain hose leading to the sink that discharges waste water is split and needs to be replaced. I have done this many times before on other dishwashers and it is usually a 5 minute job. The problem is with this dishwasher it has a casing that surrounds the entire unit, even the bottom, and the hose disappears into the casing. I have to get to the hose connection to the unit that lies inside the casing. How do I do this? I have never seen a dishwasher built like this before. Anyone have any ideas?
I can't begin to figure out how to remove this case, and I don't want to blindly start removing screws because none of them look like they obviously hold the casing on, and I am afraid of what might fall off inside the unit that I will then need to repair as well. If anyone has any information on how I replace this hose, or suggestions on a website or book where I can obtain more info I would appreciate it.
Sorry for the "off-topic" post, but I continue to be impressed by the vast array of differing talents assembled on this site. Thanks in advance.
Doug
