Old 06-07-2009, 12:09 AM
pmangelos pmangelos is offline
Default Cam Recommendations
Hi All, I m new to the world of Webers, I am in the process of putting together a 351 Windsor stroked to 427. It is a roller block, 10:1 compression, with Dart CNC'd heads, 5 speed and 3.73 gears. I am looking for suggestions on a cam, I have been looking at Comp's XFI Stroker cam. It has the following specs 114 Lobe Seperation, 248/258 Duration @.050, .608 Valve lift. Are there other cams that you guys have had good luck with, or should I give a custom cam grinder a call? Any help and or suggestions are appreciated.
Thanks,
Paul
