  #31 (permalink)
Old 06-07-2009, 10:07 AM
jdean's Avatar
jdean jdean is offline
Thanks Mark. I've got mine so that there are only two u-joints in the steering shaft, one at each end. I dont think much heat will make it that far. I am using a mechanical switch for the tail lights....I never cared for the pressure switches. Still debating on the radiator but as you can see I got plenty of room to work with since the touring chassis does not use the internally located shocks.
6th generation Texan....
