Old 06-08-2009, 02:20 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
I wouldnt be entirely happy with oil at 140° especially under full load, but the bigger issue is the condensation & the point that the oil wont be getting hot enough to boil that off. However you dont mention what the water/coolant running temp is, if this is also down around the 140/160 mark then none of the heat critical clearances like piston to bore will be optimum & it could lead to early damage like cracked piston skirts & poor ring sealing.
Jac Mac
