Old 06-08-2009, 04:39 AM
blykins blykins is offline
Originally Posted by David Kirkham View Post
I don't remember right now. I'll have to ask McLeod or look it up. It is a standard unit they use. I can't wait to give it test drive.
David
There are two twin disc McLeods available. One is the RST, the other is the RXT. The former is rated for 800hp, with two organic discs, the latter is rated for 1000 with two dual friction discs.
They will bolt up to any FE flywheel, with any pressure plate pattern. I can get them for a TKO, Toploader, Jerico, small block, big block, whatever you want to run.
If David is interested in doing a package deal, I can provide the clutch components if he wants to do the flywheel.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
