  #110 (permalink)
Old 06-08-2009, 08:21 PM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
I noticed in the original post you stated that you had the bypass hose installed. I had this exact problem and it went away after I plugged the bypass and started running water wetter. I am sure others will disagree but I am convinced that the engine is to far from the radiator and the pump will bypass rather than pump through the radiator at idle. I also drilled some 1/8 holes in the thermostat to help it bleed air through the system and installed an overflow tank.
In school 90% is exceptional, in life 10% wrong is failure.
