Old 06-09-2009, 06:59 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
Paul,
Havn't seen anything the would suit. The car that just was registered used a LED brand universal reverse light mounted under the rear of the car beteen the exhaust outlets. I will have a look at that car as well as what DRB do on their car before I decide.
I spoke to Peter on Sunday about the progress of the air con. All of the fittings are finished, they will be getting the controls via the ICC panel in the dash working when their comes back from the painter. The dash needs to be out to fit the air con unit. I will modify the the way the dash mounts to the windscreen brackets so I can get the car painted and still remove the dash.
Once all the insulation has been installed under the car and with all the required parts removed from the falcon the assembly will happen pretty quick.
Warren
