Old 06-09-2009, 12:56 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Originally Posted by edwhite7 View Post
I noticed in the original post you stated that you had the bypass hose installed. I had this exact problem and it went away after I plugged the bypass and started running water wetter. I am sure others will disagree but I am convinced that the engine is to far from the radiator and the pump will bypass rather than pump through the radiator at idle. I also drilled some 1/8 holes in the thermostat to help it bleed air through the system and installed an overflow tank.
I would go with this answer as the solution!!
