Thread: #775 update
Old 06-10-2009, 10:13 AM
patrickt patrickt is offline
Default One Obscure Option...
Ray, there is one option that you might want to speak with Doug about because it is easy for him to put it in when he's putting the car together. I spent years spec'ing out my car and this is the only option that, if I could go back, I would now add (of course I got just about every conceivable option there was). What I would have done then (and what I am doing now myself) would be to add a small removable access panel along the tunnel on the passenger side so that you can grease the front driveshaft U-Joint by merely removing the passenger seat, lifting up the carpet on the tunnel, and removing the small access panel. Trying to grease the front U-Joint fitting from underneath the car is very difficult. This is not a big-deal option; it's just cutting aluminum and adding fasteners. I guess another option would be to tell Doug not to use greasable fittings up front.
By the way, even with the battery up front you will still have a weight bias on the rear. Unless you're putting the battery in the back solely for the coolness factor I would leave it up front. I can post my corner weights if you're interested.
I didn't see pusher fans on your list. Nor did I see wind wings, Tripod lights, brake light reflectors, chip guard on the rear fenders, steel spinners (not aluminum), and of course the extra venting and heat shielding is always a good idea... I'm sure I'll think up some more after I hit the "post" button.
