Old 06-10-2009, 05:22 PM
Default 1 tank will work fine
Earlsflyincobra Earl one tank will work fine. This tank will last as long as a tank of gas. Distilled water works better than straight tap. It's only a misting unit. Make sure the flow is setup right. Just don't pump too much water through the motor. Also shut off the system and let the motor run for 20-30 seconds before turning off. This will get the water/meth mix out of the engine. The rest is test and adjust for timing and even running a cheaper gas. Rick L.
