Old 06-11-2009, 12:36 PM
elmariachi elmariachi is offline
Originally Posted by DocDirk View Post
Today we head out for a 1600 mile trek through Arizona so the system should be put to the test and we'll see if doubling the CFM (still shrouded) makes any real difference. Dirk
Post your findings back here. I expect this thread might be of value to future overheaters like us.
Originally Posted by vettestr View Post
Shroud or no shroud ? On a couple of cars where I questioned the shroud might be blocking hi way air I added shroud mud flaps.
I had a JEGS aluminum shroud we tried but it was too shallow, didn't have highway vents/flaps so it didn't work. Once I am done experimenting with pulleys for water flow and using the shop fan to increase airflow at idle, I will be going with a shrouded fan next and a radiator swap last.
I have three new Stant radiator caps I have tried in varying pressures, no effect on the overall issue. Currently I am running a 16 lb. cap.
