  #21 (permalink)
Old 06-12-2009, 06:51 AM
strictlypersonl strictlypersonl is offline
The ERA is designed for the fan to run regardless of whether the ignition switch is on and the temperature in the bottom hose (where the thermo-switch is located) is above 175F. The fan will typically shut off after a couple of minutes if it is running when the car is shut off, which indicates that when the thermostat is open, there is some thermo-siphon action going on. That small flow (encouraged by the fan-cooled air in the radiator) keeps hot spots from forming in the block and heads. Therefore, post-shutdown boil-over is less likely.
Running the fan is also a small attempt to cool the engine compartment a bit after shutdown, which might help prevent fuel percolation during heat soak. Imperfect, but it might help a little. Running the fan for a couple of minutes is not a significant draw on the battery unless something else is wrong.
