Old 06-14-2009, 06:48 AM
madmaxx madmaxx is offline
if you take off the cap and you button is flat it is because the rotor bar was not contacting. Make sure you bend your rotor bar up so that when you put the cap on you have to push down slightly to screw down. This will ensure the rotor bar is touching the distributor cap button.
It is also very easy to test the msd box. read the instructions.
