Old 06-14-2009, 05:32 PM
mjmacqua mjmacqua is offline
Cobra Make, Engine: Midstates, 501
Default Oil Line question
This may sound like a silly question, but here goes.
I have a leaking connection from the return line of the oil cooler back to the engine. (steel braided lines, 10AN connector). I want to remove the line , remove the fitting that is leaking a replace it (it is a swivel 90 degree, leaking from what looks like the swivel). confirmed fitting was tight, and took it off and cleaned it, added new telfon still leaking.
Do I have to drain the oil in order to pull that line? I believe I might because the oile cooler is at or just below the oil pan level. Can someone confirm my thought?
Thanks for your help.
Mike
