Old 06-15-2009, 06:09 AM
67JET's Avatar
67JET 67JET is offline
Cobra Make, Engine: Holliday Motorsport/396 GM / 4 speed / Jag rearend
I can see how the watts works. It does stop the front to back movement but because it rotates on the pin it lets the wheel goes thru it's travel with out getting into any bind. But how can you apply that to a factor jag hub? Where would you mount the pin? If i had a pin on the hub then i could use any linkage rods ( maybe some from Jegs or Summit) any length even make them myself.
