Old 06-15-2009, 04:36 PM
elmariachi elmariachi is offline
Originally Posted by Jerry Clayton View Post
does your demon carb have the idle eze adjustment feature in the center of the base plate? the mixture screws on just about all demon carbs that i have done anything with usually end up around 1 1/4 turns out---
And where would you suggest the Idle-Eze be set?
you seem to be quite attached to the theory that it ran ok on the dyno and before the body was on the car----so what----forget that nd work on what you have now--runs hot---no dyno involved
To borrow some words from one i've never met---if the facts don't support your theory, get a new theory( Al Nunley)
I am not attached to it as a theory, its the facts. Do you have a recommendation?
