Old 06-16-2009, 07:16 AM
Monster's Avatar
Monster Monster is offline
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
Russ,
I looked at going with Hoyle, but decided on Fast Cars because I wanted to use the 6-pin hubs and the JFZ calipers. Making the spindles and adapting the 6-pins was above my paygrade. So, for that reason I decided to go Fast Cars.
I'm not sure I follow your hub/spindle comment, I used my 6-pin SPF hubs and have JFZ calipers on my car
Jet- Since I'm only framiliar with the Hoyle upgrade proceedure I can say that the mods to the X-member do require you to cut & weld (it is pretty easy). The whole conversion took about 8hrs. to complete.
As we have both said, either way you go you will be better than the stock lever shock set up you currently have with the MGB suspension.
Mike
