Originally Posted by maxum_101
ok i backed off the jam nut to allow the fork to move back more, i backed it off all the way to the end of the threads approx quarter inch, and put it all back together, and yet there seems to be pressure pushing on the fork, mind you not as much as before but i still dont have that air gap as some have posted, if i pull back on the fork it will move back pushing the rod into the hyd cyl giving me that air gap but when i let go of it it pushes out the fork again putting pressure on the t/o bearing.
I would try a couple of washers as spacers to move the slave away from the fork a little and then I would also incorporate a spring to pull the fork in towards the slave to remove all pressure from the TO bearing.
