The weights cause no issue why in the world would you want to remove them? They are not the source of the noise in this thread. He has generic gear rollover noise. The reason it gets louder when the car gets warmer is the trans fluid warm and in turns thins out and there is less lubricity cushion to dampen the noise.
Originally Posted by Cobra 29
I have a Centerforce PP with the weights and a new TKO600, after reading this, I think I want to remove the weights. Can this be done with the engine and transmission in the car? I thought I remember reading a thread where a CC member successfully removed the weights and bar that holds the weights via the fork splot in the bellhousing. I believe he said he counted 18 weights so he knew that he removed them all and left none at the bottom on the bellhousing.
