Old 06-19-2009, 07:44 AM
madmaxx madmaxx is offline
Beautiful and a true man and gentlemen with the lift!!!!! On a side note I want you to watch your remote reservoir for your clutch. If you find it leaking you can try to tighten the clamp, but the permanent solution is to drain, remove and seperate the two halfs, apply seal all in the o-ring area, reassemble install and be leak free.
