Old 06-19-2009, 08:50 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Filippo,
Its pretty difficult when there are no pictures. Best suggestion is to remove the driver side and see how they engineering the mounting of the door panel. I am sure you want to remove the panel with aleast damage as possible. This is why I am suggestinging to look at the driver side.
may be you can creat a tool to unlatch the door but first looking how the latch system works on the driver side. Once you get the door open (passengerside) the door panel should be a cinch
maybe a long thin hanger to unlatch the door. Try having someone push in the door to take the pressure off of the latch.
