Old 06-19-2009, 07:58 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Have you tried bleeding the system or checking the adjusting rod on the slave cylinder? When you are stopped and the noise is happening are you in neutral or do you have the clutch pedal depressed and in gear? If depressed, if you slightly let up on the pedal, does the noise change or stop?
SPFWiringDiagrams@Comcast.net
