Old 06-19-2009, 08:06 AM
zzmac's Avatar
zzmac zzmac is offline
Cobra Make, Engine: Superformance, Roush 402R
Normally I'm in 3rd gear, I'll depress the clutch and as I'm coasting to a stop I'll shift into first. So the car's in gear when I'm stopped. I haven't tried anything mechanical as yet and haven't tried letting up on the pedal to see if it stops.
Originally Posted by Blas View Post
Have you tried bleeding the system or checking the adjusting rod on the slave cylinder? When you are stopped and the noise is happening are you in neutral or do you have the clutch pedal depressed and in gear? If depressed, if you slightly let up on the pedal, does the noise change or stop?
