Old 06-19-2009, 01:52 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The throw-out bearing rides on a set of rollers. I just replaced mine, and it spun freely, but it was somewhat deformed: that is, both pieces were no longer concentric about a common centerline. I'll bet your clutch slave rod just needs to be adjusted to just break contact with the fingers. The fact that you said it goes away after a second or two sounds like a lag time in the hydraulics allowing it to rub momentarly. Is there a spring on the slave cylinder piston?
SPFWiringDiagrams@Comcast.net
