Old 06-20-2009, 04:56 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by jab View Post
There is a separate plenum for the IAC installed under the manifold that is considerably larger than the stock plenum that comes with the TWM. We had to locate it under the manifold as there is no space on top.
OK. What do your VE and spark tables look like in the 9 cells surrounding where the car idles when its warm? What do the MAP and RPM values do when your car tries to idle? What are your target and actual Air to Fuel Ration (AFR) at idle? Is the car in closed loop at idle - if so, how much O2 correction is being applied? Do you have MAP Acceleration enrichment turned on - if so what are those settings? Finally, can you check the setting for Min TPS for idle and let me know what you actual TPS value is at idle? Also, does your accell system have a timming trim feature for idle? If you can send this information to me, I will try to help you to get the car to idle.
- Fred
