Old 11-21-2001, 09:42 PM
BT SNAKE's Avatar
BT SNAKE BT SNAKE is offline
Cobra Make, Engine: Midstates Cobra, RFGT40
Thumbs up
Hey Moondog,
Go over to the Edelbrock sight and check out their Pro-flo injection unit. It comes with everything you need to make the swap. It even has the computor module so you can infinitly tune it. It's easy to use too. I have this unit on my SBC and it's the best thing I ever did for this motor. The neat thing about it is that you get the fuel pump , all the hoses, the wire loom and all the electronic too. It took me about 6 hours to put it on. Also any 4 barrel air cleaner will work on it too. The injectors are in the manifold not the throttle boby like some after market stuff. My performance increased considerably. For under 2K it's the biggest bang for the buck. You will spend that much just for the accesories for the TPI. My 34 ford has the TPI and there is no comparison. I can't adjust the TPI because the program to do so costs over $300 . Then you have to have a lap top too.
It's worth a look. I think you will like it.
Hersh
