Old 06-20-2009, 10:45 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
something to consider----usually a higher pressure spring or higher volume pump will just cause more bypass oil back into the pan, which results in higher temps, excess spray into an already turbulent atmosphere, and possibly worst foaming
It would be wonderful if a pump/system could easily be used that was the correct flow for the system without over sized gears or higher pressures
