Thread: Roller CAM -FE
Old 06-22-2009, 12:52 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by Jamo View Post
If you want a roller cam setup...hydraulic roller cams offer the best apllication for street use. If you're on the track the majority of the time, then a solid roller will provide great runup for high rpms with a little forethought in replacing the bronze gear regularly (or finding the elusive composite gear).
I'm not all that educated on this whole distributor gear problem. Honestly, all I did was tell Keith Craft that when he shipped my MSD distributor to custom curve it to spec for the cam and application, and to put whatever gear he thought was best for the cam he was supplying. It came with a bronze gear on it. Are you saying that this bronze gear will be a problem? Are you also saying that hydraulic roller cams don't have a distributor gear problem but solid roller cams do? I wasn't aware of that. Any idea why they would be different? Thanks.
