Thread: Roller CAM -FE
  #42 (permalink)
Old 06-22-2009, 07:16 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Would you go so far as to say "If it were not for the break-in and lash adjustment issues, a solid flat tappet would be superior to both a hydraulic flat and hydraulic roller cam?"
Is there not an inherent advantage to a roller (either hydraulic or solid) that within a given lift, duration and overlap profile, the roller allows for a more aggressive (quicker) opening and closing of the valve via a more aggressive lobe profile than is possible with a flat tappet with the same specs? I was always under the assumtion that this was one of the biggest advantages of a roller over a flat tappet cam. Again, maybe I'm all wet here, but.......
