  #153 (permalink)
Old 06-22-2009, 09:26 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by sgianino View Post
Hi Fred,
I might of sent this over to you before but if not here it is....
http://www.ktrmotorsports.com/service/dynamometer.htm
They did a Chassis dyno for me a few years back,nice guys and very professional.
Im very curious to see your actual Dyno numbers to compare our similar motors(Well similar in the sense of the same builder) :-)
Hope to see you soon!!
Sal
Thanks Sal. Appreciate the information on the Dyno shop that you used. Base mapping of an EFI system requires a Dyno which can hold the rear wheels at a fixed speed while the dyno is under load. Do you know if the shop you worked with had this type of dyno. The other type is called an intertial dyno which measures power by how fast the car can spin up a heavy drum. This later type is great for measuring power output on a tuned car during a sweep but it cannot be used for base tuning of an EFI system.
Thanks for the info!
- Fred
