Old 06-23-2009, 03:16 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Hard lines are usually safer and less prone to deterioration over time. A 3/8" hard line attached to the frame will be plenty, but some guys insist on using 1/2" hard line (you know, bigger is better routine). If you want to use -AN braided hose and fittings to connect to the tank and to the mechanical fuel pump up front, there are -AN braided fittings available to adapt braided hose to hard tubing. Since the Cobra wheel base is 90" you should have a significant hard line run of at least 84". In my opinion, hard line under the chassis is just safer but should always be routed in a protected position and secured with padded clamps. Of course, any hose used should be certified for use with fuel.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
