Old 06-23-2009, 06:01 PM
RodgerH RodgerH is offline
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Originally Posted by SuperHart View Post
Hard lines are usually safer and less prone to deterioration over time. A 3/8" hard line attached to the frame will be plenty, but some guys insist on using 1/2" hard line (you know, bigger is better routine). If you want to use -AN braided hose and fittings to connect to the tank and to the mechanical fuel pump up front, there are -AN braided fittings available to adapt braided hose to hard tubing. Since the Cobra wheel base is 90" you should have a significant hard line run of at least 84". In my opinion, hard line under the chassis is just safer but should always be routed in a protected position and secured with padded clamps. Of course, any hose used should be certified for use with fuel.
Wow....mechanical fuel pump up front? Did you even read my original message?
To all of you who have offered on-topic feedback….thanks!! Anyone else out there running braided fuel hoses want to share info?
Rodger
