Old 06-23-2009, 08:04 PM
lemans24 lemans24 is offline
Cobra Make, Engine: kirkham stroker 48 webers
my kirkham has braided all the way. to attach the AN fittings,i marked the hose with a sharpie and put a plastic zip tie on the mark. secure very tight and use a dremel tool with metal cutting blade. it works great. wear gloves. i found, if you spin the fitting it will go all the way on. make sure all the stray braided pieces are in the fitting before trying to spin it
