Old 06-23-2009, 09:27 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Not sure there is a better way or place to measure oil temp. If your sensor is in a remote filter housing it will display a bit lower than if measured in the blocks main oil galley. This is the reason the oil is 210+ and coolant is 180+ as it depends where or what you are monitoring.
Maybe just adding 2 quarts to the system when installing a cooler is that buffer that gets you over the hump but it does help. The same extra volume makes a T-stat a good investment.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
