Originally Posted by RICK LAKE
priobe Phil The reason you have low idle oil pressure is the crankshaft. If it is the nascar steel shaft, IT"S CROSSED DRILLED. It uses twice the normal oil and cuts the pressure twice as fast. Rick L.
So Rick, is it your opinion that his idle
oil pressure is normal for an engine with a cross-drilled crank?
