  #26 (permalink)
Old 06-24-2009, 12:38 PM
elmariachi elmariachi is offline
Originally Posted by RICK LAKE View Post
priobe Phil The reason you have low idle oil pressure is the crankshaft. If it is the nascar steel shaft, IT"S CROSSED DRILLED. It uses twice the normal oil and cuts the pressure twice as fast. Rick L.
So Rick, is it your opinion that his idle oil pressure is normal for an engine with a cross-drilled crank?
