Old 06-24-2009, 02:08 PM
patrickt patrickt is offline
Default C'mon Rick, I've got documents in the manilla envelope...
Originally Posted by elmariachi View Post
So Rick, is it your opinion that his idle oil pressure is normal for an engine with a cross-drilled crank?
Uhhh, Rick... isn't it true that the oil pressure sending unit for oil pressure lights was pre-set to 7 psi at the factory? And, the owner's manual assuaged the driver by telling them that it was perfectly normal for the light to flicker when coming to a stop? (N.B. -- Unless you admit to both of these, you'll just force me to post the excerpts from the service and owner's manuals.)
