06-24-2009, 07:17 PM
Originally Posted by RICK LAKE
1 of the builders on this forum and others said that the Scat kits redid the oiling of the crank shaft. The oil is pushed in the rod bearings about 30-50 degrees after or before TDC. I forgot which it was. This pressure helps keep the bearing off the crankshaft on the compression cycle and even more important the exhaust cycle.
