Old 06-25-2009, 09:47 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by elmariachi View Post
So you are saying either:
1. The 10-12 ounces of coolant that is leaving your system (and now going in that plastic bottle) is enough to make your temperatures fluctuate to such erratic levels; or
2. You had more air in the system that needed to be burped out; or
3. You needed more radiator cap; or
4. Some combination of the above.
I am surprised anything can get past that 20 lb cap, but maybe that's common for that engine platform.
1. It's a 1 liter bottle so it is shifting out more like a quart.
2. I might have had more air. When I started the engine to warm it up the expansion tank was empty. I let the engine warm up again and slowly added water (no more experimenting with 50/50) until I could see it flowing again but then it go too turbulent so I turned the engine off and then filled and capped the tank. There was a little water in the bottle to provide a vacuum. Then I took it for the drive.
3. I did put a 20lb cap on an yes, it still blew some by.
This morning when it was cool it had not pulled back into the expansion tank as I expected. That could be because the cap is just too much. The bottle was about 1/2 full and the tank was just below the baffle line so there was no loss in the system. I may try the 16lb cap again to see if it'll pull back.
I'll go on the search for a bladder-type overflow I guess.
Hard to believe the engine produces that much heat but I guess it does.
