  #23 (permalink)
Old 06-25-2009, 01:14 PM
elmariachi elmariachi is offline
Originally Posted by twobjshelbys View Post
Probably more burping but we'll never know since more than one thing changed. The 16lb cap I have is vented so the coke bottle recovery will not work with it. Not too interested in going back since this is so much of an improvement.
Per the previous I'll probably stick with 160 but go to the high flow.
So you could go run it with the 160 and then another run with the 180 and compare. If it didn't draw the coke bottle contents back in then a recovery system is not the answer. If burping it was the solution you should be able to run with your current t-stat and either radiator cap and be fine. A hi-flow won't matter, IMO.
