Old 06-27-2009, 01:43 PM
Bill Bess's Avatar
Bill Bess Bill Bess is offline
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Be careful running those extremely high pressure radiator caps. If your using an old style Ford surge tank keep the cap pressure 16 lbs and under, I'm runnig a 13 lb. cap and it works just find, plus a recovery tank that contains any fluid that gets by the cap after shut down ...it then is sucked back into the radiator. My water level is always perfect.
A super h P cap can cause leaks,,,,soft plugs, gaskets, hoses etc....if that occurs just dump in a little Alumi seal...fixed.
It's all about air flow on these little cars, when it's 115 degrees in Havasu I can count on the temp. getting up to 210 at long signals..but quickly going back to 190 to 195 on the road without the fan on.
Bill
