Thread: 48 IDF jetting.
  #21 (permalink)
Old 06-28-2009, 04:59 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Default Too rich....
After testing on a proper situation (autoslalom- between cones on a track) , I found the middle/ transition to be too rich.
To make things better, can the nuts on the acc.pump shafts be turned innwards (from the valve covers towards the carb- body)?
Can the large idling jet (65) be causing this trouble? (Transition holes are fed by this jet ...)
Or can the 0 (closed) acc.pump bleed be part of it?
Also; after reading an older post by JacMac I've found a probalbe cause of two barrels unwilling to be synchronized; twisted shafts!?!
I'll look into things and hopefully things will get even better....
