You would be better with a larger single filter
Michael C Henry Mike I have run dual filters and they are not worth it. We use them. You might want to look at getting larger lines, like#12 or #14 with hiflow connectors. Getting a large 2 quart single filter hiflow. This is what they use on medium size diesels motors. Winx or Mobil 1 sell this filter with a large inlet and outlet. It's either 13/16 or 7/8". For your application there will not be any restriction. I will look and see if I can find the numbers of these parts for you. I am going the same way with my next motor. Everything is larger inlets and out lets. Lines, connectors, cooler, and dry sump pump. Rick L.
